Flashing colours on map
1793
03-31-2025 12:19 PM
Bee24601
Whenever I move the cursor or zoom in and out of my map, the whole map flashes pink and blue and blocks of colour appear and obstruct sections of map near the polygons I created, is there any way I could get this back to normal?
DanPatterson
MVP Esteemed Contributor
you have to change to a new symbology perhaps
and I would suggest running a Check Geometry on your polygons incase something is amiss with it. or something you were doing with it
Tools for checking and repairing geometries—ArcGIS Pro | Documentation
... sort of retired...
ThomasHoman
What version of Pro are you running?
Have you updated your video drivers?
Bee24601
Thanks for responding,
my video drivers are up to date and the version I am using is 3.4, the map was completely fine until I changed the symbology on the two layers, one of which held my polygons, so I am thinking it may have something to do with that? But I don’t know how to get rid of the colours
DanPatterson
Bee24601
Thank you for you’re advice,
I have run the geo check and it came back saying no problems were found, I’ll try changing the symbology and see what happens.
JeremyWright
you didn't post a picture but this could be a known issue with certain GPU drivers (usually intel integrated graphics) and DirectX12.  Try opening display options and changing the Rendering Engine to DirectX 11 instead.  If this fixes it then you can update your GPU drivers from computer or GPU manufacturer's site to resolve the issue permanently.
