Fixed point Symbology
2139
5
03-10-2024 05:23 AM
HusamJubeh
Hi all
I want to fix the size of the points through Symbols.
The default format is that the Symbol size changes with the map scale.
Can it be fixed ??
Thank you
Eugene_Adkins
You can turn off the scale based option. There’s also other links about working with symbols at the end of the documentation.
MErikReedAugusta
MVP Regular Contributor
You might also want to look into the Reference Scale options.  Right-click the map, itself, at the top of your Contents pane, and click 'Properties'.
I forget the exact location off the top of my head, but I believe it might be under "Extent Options" in the General setttings.
Zoom your map to what looks reasonable to you, note what that zoom level is, and put that zoom level in the reference scale box mentioned above.  Then, no matter how much you zoom in or out, all of your symbols will stay the same size, relative to that zoom.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
HusamJubeh
Here is it true?
AlfredBaldenweck
MVP Frequent Contributor
Reference scale is set in Map properties, not by layer.
MErikReedAugusta
MErikReedAugusta_0-1710193795321.pngMErikReedAugusta_0-1710193795321.pngMErikReedAugusta_1-1710193800876.pngMErikReedAugusta_1-1710193800876.png
M Reed
