Fishnet Grid cell sizes not uniform
1177
04-08-2024 11:51 PM
cskari
Hi All
I created a 0.01 degree grid (fishnet) in ArcGIS Pro for NSW, Australia. I used GDA2020 coordinate system.
I calculated some statistics inside grids. It seems like grid cell areas are slightly different. Can somebody explain this to me?
Thanks
DanPatterson
MVP Esteemed Contributor
If you used geographic coordinates to specify the cell dimensions then projected it or used a projected area to get its planar dimensions, then the cell sizes will be different because of the fact that that the EW extent of a cell decreases as you head poleward becoming a point at the poles
Geographic coordinate system - Wikipedia
... sort of retired...
DanPatterson
