First Time Using Summary Statistics
1253
08-13-2021 09:59 AM
Surya_Vaidy
Hello!
This is my first time using summary statistics to calculate the frequency of points. I have joined my points to a roads layer, and I was wondering if can select a specific road on which to calculate the frequency of points. Also, I've been trying to find an option to add weight to the calculation based on a category, but I haven't been able to find it. Is the weighted calculation a different tool I have to use in tandem?
Thank you for your time and help.
DanPatterson
MVP Esteemed Contributor
You didn't show your resultant table.  The weight can be applies via a field calculation, probably with a small script if you have the parameters defined already
... sort of retired...
