Find Identical Tool script with multiple xy_tolerance values
1173
08-15-2023 06:55 AM
ThomasPlazek
Hi, I am working on trying to write a script to identify point data within a certain distance of each other. This point data is broken down into 6 types as well. These types have different xy tolerance values, so I am trying to assign the xy tolerance to each type, then loop through each of them and output the results into a separate table for each type. The issue is that ArcPro is just putting all of the original points into every output table and assigning them all to the same FEAT_SEQ. Every output table is identical. Any help would be appreciated!
*note:  for privacy reasons, I have redacted the output gdb location
import arcpy
output_workspace = r"GDB_location.gdb"
location_domain = {
"Depot": 100,
"Station": 100,
"Stop": 5,
"Yard": 100,
"Switch": 5,
"Level_Crossing": 5,
try:
for location_type, xy_tolerance in location_domain.items():
output_feature_class = arcpy.CreateUniqueName(f"Identical_{location_type}", output_workspace)
arcpy.management.FindIdentical('Railway_POI_1', output_feature_class, ["shape"], location_domain[location_type])
print(f"Duplicated records for {location_type} have been identified and saved to {output_feature_class}.")
except arcpy.ExecuteError:
print(arcpy.GetMessages())
ThomasPlazek
As it turns out, the Find Identical tool has some limitations and does not allow you to use different xy tolerance values for different types within the same feature class. My solution was to break down each type into its own feature dataset and assign a global xy tolerance to each type. The SRID was set to WGS84 in this case, but it could be changed as needed.
import arcpy
import re
arcpy.env.workspace = r"host_gdb_location"
input_feature_layer = "Railroad_POI_1"
field_name = "TYPE1"
unique_values = set()
with arcpy.da.SearchCursor(input_feature_layer, field_name) as cursor:
    for row in cursor:
        if row[0] is not None:  # Exclude null values
            unique_values.add(row[0])
xy_tolerances = {
    "Depot": "100 Meters",
    "Station": "100 Meters" ,
    "Stop": "5 Meters",
    "Yard": "100 Meters",
    "Switch": "5 Meters",
    "Level_Crossing": "5 Meters"
for value in unique_values:
    sql_expression = f"{arcpy.AddFieldDelimiters(input_feature_layer, field_name)} = '{value}'"
    arcpy.SelectLayerByAttribute_management(input_feature_layer, "NEW_SELECTION", sql_expression)
    selection_count = int(arcpy.GetCount_management(input_feature_layer).getOutput(0))
    if selection_count > 0:
        sanitized_value = re.sub(r'[^a-zA-Z0-9_]', '', value)[:40]
        if not sanitized_value:
            sanitized_value = "Unknown"
        feature_dataset_name = f"FeatureDataset_{sanitized_value}"
        arcpy.CreateFeatureDataset_management(arcpy.env.workspace, feature_dataset_name, arcpy.SpatialReference(4326))
        feature_class_name = f"FeatureClass_{sanitized_value}"
        feature_class_path = arcpy.CreateFeatureclass_management(feature_dataset_name, feature_class_name, "POINT", "", "DISABLED", "DISABLED")
        arcpy.management.CopyFeatures(input_feature_layer, feature_class_path)
        xy_tolerance = xy_tolerances.get(sanitized_value, None)
        if xy_tolerance:
            arcpy.env.XYTolerance = xy_tolerance
        find_identical_output = f"FindIdentical_{feature_class_name}"
        arcpy.FindIdentical_management(feature_class_path, find_identical_output, ["Shape"], output_record_option="ONLY_DUPLICATES" )
        arcpy.env.workspace, identical_output_table, where_clause="FEAT_SEQ >= 1")
        arcpy.env.XYTolerance = None
        print(f"{selection_count} features of type '{value}' processed.")
    else:
        print(f"No features of type '{value}' selected.")
arcpy.SelectLayerByAttribute_management(input_feature_layer, "CLEAR_SELECTION")
ThomasPlazek
import arcpy
import re
    for row in cursor:
xy_tolerances = {
    "Stop": "5 Meters",
        if xy_tolerance:
    else:
