file geodatabase from arcmap does not work in ArcGis pro ?
1844
06-26-2023 09:28 AM
spiderman90
Hello ,
what I know that to let the feature dataset from sde database in  arcmap to  work in ArcGis pro .
i have to upgrade feature dataset .
What about file geodatabase ?
i have exported file geodatabase include feature dataset and feature classes from arcmap .
to let the file geodatabase work in ArcGis pro ,should I still upgrade feature dataset ?
if yes ,how .
Because I have tried to use upgrade feature dataset but it does not show me all feature classes ,it show me only annotation what about feature classes for points ,lines and Polygons
my problem :
i have added the file geodatabase to catalog in ArcGis pro to show the content ,it shows me the feature dataset includes the name of each feature class but when I click to open the table ,i got message that failed to open the table
but when i add the same file geodatabase into arcmap ,it shows me the tables without any problem .
so I am wondering if there is something should I do ,to let it work on ArcGis pro ?
George_Thompson
Esri Notable Contributor
Is this data the same that has the COM components?
If so, you may need to add the ArcFM reader for Pro to get it to work correctly.
--- George T.
spiderman90
Where could I find reader of ArcFM ,then I will try .
but I have asked about the data and they said it has no relation any more with ArcFM .the data is only geometric network .
but I can try to use ArcFM to check if it make any difference
George_Thompson
Understand, I am not sure where (or if) the ArcFM reader for Pro is located. This was just something that would help understand where the issue is.
--- George T.
Jordan_Brasher
Esri Alum
Typically, in order for an upgrade to a dataset to take place, an upgrade to the geodatabase in which it is housed needs to be performed first. Have we attempted to upgrade the geodatabase?
