Fields scrambled after editing
1076
12-18-2024 09:59 AM
Labels (3)
GISLandSearch
Whenever I edit my layer using the Edit Ribbon in Arcgis pro I can delete a shape. But then whenever I hit "save edits" the data in the fields gets scrambled.
If I have Field A, Field B, Field C
half the data from field B will merge with Field A, the data from field C will move to field B and Field C will be empty.
I have updated Arcgis, downloaded a new data set, created a new project. Nothing seems to fix his issue.
AlfredBaldenweck
MVP Frequent Contributor
Does it actually scramble the data or is it just a graphical bug? Like, if you close and reopen the table, does it fix it? If you remove the layer and re-add it, does it still have the problem?
Robert_LeClair
Esri Esteemed Contributor
This is really odd and not something I've seen before.  First I would recommend completing a soft reset of ArcGIS Pro.  Is it possible to share the data with me for testing purposes?  My email address is rleclair at esri dot com - thanks!
