Fields: Precision and Scale
3697
07-07-2023 04:35 AM
SimonSchütte_ct
MVP Regular Contributor
When I create a new Feature Class in ArcGIS Pro, this are the field settings:
When I export the Feature Class as Shape file and look at the field settings, it looks like this:
I only found this on the topic: How To: Customize Numeric Data Precision and Scale in ArcGIS Pro (esri.com)
But if we look at the screenshot here How To: Round off Numbers to a given Number of Decimal Places in an Attribute Table and La (esri.com... precision and scale are not listed:
When I set the Decimal places in Number format to 5 and export the Feature Class to Shape, this is the result:
It would be great if someone could explain this behaviour 🙂
DanPatterson
from
Add Field (Data Management)—ArcGIS Pro | Documentation
Note:
Field precision and scale are not supported in a file geodatabase feature class or table. If you enter a value for precision or scale, it will be ignored.
subsequent to the Note is more description as to what happens and what field types are specified for data types
... sort of retired...
DanPatterson
from
Note:
