Field map resetting in modelbuilder
1298
04-01-2025 02:00 PM
YusefSamari
I am using ArcGIS Pro 3.4.3 with everything stored in File Geodatabases.
I made a model not very long ago, one of the first steps of which was to Select a layer by location, then export this using the Export Features tool, and in that process drop several of the fields and rename several others using the field map. It was running fine when I last used it a couple of months ago. I just tried it now and it failed on one of the later steps, because the field map has been reset. It now contains all of the original fields, none of them renamed. Does anyone know why this happened and how to prevent it?
Tags (1)
DuncanHornby
MVP Notable Contributor
I too am experiencing this behaviour in 3.5.1 and believe its some sort of bug introduced by ESRI. I have the simplest of models as shown below. On each iteration the field map is lost/reset. The inputs have the same schema they are simply being exported with field lengths being adjusted.
Its really frustrating and makes automation in modelbuilder impossible.
I've tagged a few others who use modelbuilder and may have a solution?
@ShitijMehta , @KoryKramer , @curtvprice
NevilleWilson_Everick
I have the same issue in arc pro 3.3 using the buffer then append tool. And as soon as you run the model once, or change anything, all the field mappings are lost - and the tools cannot even read back to the input or target layers attribute fields.
I just upgraded and tested on 3.5.4
and its still a bug
not happy
ShitijMehta
@DuncanHornby I just tried the case, not sure I am seeing the same issue with 3.6.
Just to confirm, please could you share some steps and what you see after the model runs. I can retry just to make sure I am following the exact steps.
Thank you!
