Field Calculator — Sort values, partitioned by GROUP_ID field
1284
08-22-2024 10:42 AM
Bud
Legendary Contributor
ArcGIS Pro 3.3.1; file geodatabase
GROUP_ID VALUES
1 0
1 1
1 0
2 0
2 0
3 1
3 0
3 1
I want to rearrange the VALUES data so that the values are sorted descending, sorted within each GROUP_ID partition.
GROUP_ID VALUES
1 1
1 0
1 0
2 0
2 0
3 1
3 1
3 0
How can I do that using the Field Calculator?
I’m aware of the Sort geoprocessing tool. But I don’t want to use Sort because it outputs a separate FC. I want to update the original FC directly. And I would prefer not to use the Sort tool, join it back to the original FC, and then do a filed calculation to bring in the joined/sorted values.
I don’t want to sort the rows, I want to edit the values and leave the row order as-is.
JoshuaBixby
MVP Esteemed Contributor
Why does it have to be Calculate Field?  This is much more straight-forward with cursors.
Bud
I’m inexperienced with Python, so I assumed a field calculation would be easiest. I hadn’t considered a Python cursor script in the Python Window as an option. But if that’s easier, then it would be fine.
JoshuaBixby
With Calculate Field, there is no way to ensure row order, truly ensure it.  So, doing order-dependent row operations is kludgy at best and generally error prone.  With cursors, you can specify an ORDER BY statement to ensure row order, or you can loop through a cursor twice using a dictionary to store and update values.  If someone else doesn't offer up some code, I will take a look in a day or so.
