Field Calculator Python IF statement
48278
8
05-28-2017 03:18 PM
MarcoOrlandi1
Hi everyone,
I’m trying to use IF statements in field calculator to fill a field starting from another field’s values:
Field to fill up: Historic_period
Field already filled: Century
Statement in human language:
IF Century = 6 then write “late antiquity”, IF Century=10 the write “Middle age” etc etc.
I’m struggling trying to set up the correct syntax in ArcGis Pro Filed Calculator but I’m always missing something…..
Can someone help and guide me step by step (I don't know how to use the helpers and the Code Block....)?
Thanks in advance,
Marco
DanPatterson_Retired
without getting into specifics for your case... examine this image and return with questions.  In ArcMap
And so you can see the similarities and difference in PRO
KatR_
Thank you for the comparison, very helpful!
Do you know how to format for a string input as the condition to hunt for when calculating the field?
Ex. (Build_Code is the field to calculate, Build_Type is the conditional field)
Build_Code =
Type(!Build_Type!)
def Type(fld):
      if fld == "Neighborhood"
            value = 1
      elif fld == "Apartment"
            value = 2
      elif fld == "Condo"
            value = 3
      return value
Kat, you are missing : 's at the end of your if lines
def Type(fld):
    if fld == "Neighborhood":
        value = 1
    elif fld == "Apartment":
        value = 2
    elif fld == "Condo":
        value = 3
    return value
The field you are calculating values for should be of type 'short' or 'long'
and the 'expression' for that field would be
Type(!Build_Type!)
where the !Build_Type! is the field containing the text classes.
GJB
Hello, this is an excellent post. In PRO I am trying to do essentially the same thing as KatR, except need to replace !prim_lith! (a text field with geologic material descriptions, eg, clay) with a new !prim_lith_reclass! (a short integer field) whose value depends on the geologic material.  The Expression is valid but the return values are all equal to 1 (should be 1-9). I've tried varied syntax etc. but nothing seems to work.  Any insights would be greatly appreciated!  Thank you.
JoshuaBixby
MVP Esteemed Contributor
If statements are executed in order, so looking at your first statement:
if fld != "Soil or Fill:
Every record but those with "Soil or Fill" will return True, which means they all will get mapped to the value 1.  Records with "Soil or Fill" will be caught by the second statement
elif fld != "Alluvium":
and get mapped to the value 2.
In short, given your existing if statement structure, records can only have a value of 1 or 2 with most of them all being 1.
Bud
In my opinion, calculated columns should be easier in ArcGIS Pro: Virtual Attributes (ad hoc).
I want to be able use SQL like this:  case when a<>b then 1 end  .
To me, that would be better than creating a new field in the FC and fumbling with the field calculator.
This post has ~42,000 hits. And there are ten other posts like it. That suggests to me that field calculator IF statements need improving.
JonathanNeal
@Bud The where clause is supported in the calculate fields tool.  If you are just doing one calculation, use Select Layer By Attributes then calculate.
Tool Doc: Calculate Fields (multiple) (Data Management)—ArcGIS Pro | Documentation
JonathanNeal
@MarcoOrlandi1 Peaced what you had into this:
arcpy.management.CalculateField(
    in_table="Your_table",
    field="Historic_period",
    expression="calc_historic_period(!Century!)",
    expression_type="PYTHON3",
    code_block="""def calc_historic_period(century):
    if century == 6:
        return "late antiquity"
    elif century == 10:
        return "Middle age"
    else:
        return "Other" """,
    field_type="TEXT"
