Features from feature service layers are not displayed in saved Pro projects since v3.0 upgrade
4102
10
08-26-2022 09:26 AM
MollyMoore
Since upgrading to ArcGIS Pro 3.0, features from feature service layers from our organizational map server are not displaying in saved Pro projects. When opening a saved project, the feature service layers are visible in the Contents pane, and the attribute table can be opened normally, but the features are not visible on the map. If the  the feature service layer is removed and re-added to the saved project map, it is still not visible. This occurs with Projects created prior to the v3.0 upgrade and those created after. Feature service layers display fine if opening a blank project.
This is consistent across all those in our organization who have upgraded to v3.0
Is anyone else experiencing this or have any ideas about what could be going on?
MollyMoore
Thank you, @JeremyWright , we will follow up with ESRI Support and see if they can replicate.
