feature layer created in AGOL doesn't have attributes in Arc Pro
777
04-14-2024 06:05 AM
Labels (2)
BrianTickle
I've created a hosted feature layer in AGOL that contains pts, lines, and polygons.  The feature layer allows photos and files.  The feature layer also contains one polygon.  When I add the feature layer into Arcgis Pro, the polygon appears, however the attribute fields don't appear.  I've tried selecting the feature to see if it populates the attribute table.  I've also tried drawing a new polygon to see if that will populate the attribute field.  However, i get the error: "Failed to create new feature.  the field type is invalid or unsupported for the operation."  Any help would be appreciated here.
Alternatively, is there a way to add a "photos and files" field to an existing feature layer in AGOL?  I can't seem to find a way to do this.  Thanks!
