Feature Class Added to Map Won't Draw
2531
03-28-2024 10:19 AM
JasminePrater
My coworker is having an issue with some layers not drawing when added to a map in ArcGIS Pro that come from a new SDE we created.  I created the SDE, but she uploaded most of the layers to it.  We used the same administrator account to build the database and we built it under the guidance of Esri Professional Services.  Earlier today, she added Branch Versioning to the datasets and we are on a SDE schema.  When she added one of the point features with about 100 points, it failed to draw.  We tried changing what field the symbology displayed, but that did not help.  The only way she can get the layer to draw is if she closes the project and reopens it.  It should be noted that we are preparing to publish the layers as services for use in our new Portal instance, but have not done so.
This also occurred when she used our test SDE we previously created.  This SDE was created with the DBO schema and was Traditionally Versioned.  This problem has not happened to me when I open the data for either SDE.  We both have the most current version of ArcGIS Pro.  Does anyone have any insight as to why this is occurring, how we can fix it while the project is open, and/or how we can prevent it from happening in the future?
George_Thompson
Esri Notable Contributor
I connected with Jasmine on this. There was an issue with a field domain and symbolizing by that field.
She recreated the FC in the geodatabase, appended the data and correct domains. Then copied back into the correct FDS. We were able to symbolize correctly after that point.
Seems like Pro did not like that feature class.
--- George T.
George_Thompson
Once you branch versioned the data, you added that feature class back to a Pro map and that is when the issue occured?
--- George T.
George_Thompson
--- George T.
