Failure when trying train deep learning model
1205
06-07-2023 06:49 AM
DimasPratamaPutra
I failed to execute train deep learning model and this is the error message. Please help me
Train Deep Learning Model
Parameters
Input Training Data 'C:\Dimas\11. Astra Agro Lestari\Probation\Palm_Tree_Detection\Kolovai\imagechips'
Output Model C:\Dimas\11. Astra Agro Lestari\Probation\Palm_Tree_Detection\Kolovai\classifypalm
Max Epochs 50
Model Type SSD
Batch Size 64
Model Arguments grids #;zooms 1.0;ratios '[1.0, 1.0]';chip_size 224;resize_to #;monitor valid_loss
Learning Rate
Backbone Model RESNET34
Pre-trained Model
Validation % 10
Stop when model stops improving CONTINUE_TRAINING
Output Model
Freeze Model FREEZE_MODEL
Environments
Processor Type GPU
Messages
Start Time: Wednesday, 07 June 2023 20:28:05
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 308, in execute
data_bunch = prepare_data(in_folders, working_dir=out_folder, **prepare_data_kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\learn\_data.py", line 2240, in prepare_data
ObjectDetectionItemList.from_folder(path / "images")
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\fastai\data_block.py", line 479, in _inner
self.train = ft(*args, from_item_lists=True, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\fastai\data_block.py", line 303, in label_from_func
return self._label_from_list([func(o) for o in self.items], label_cls=label_cls, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\fastai\data_block.py", line 303, in <listcomp>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\learn\_data.py", line 325, in _get_bbox_lbls
return _get_bbox_classes(
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\learn\_data.py", line 269, in _get_bbox_classes
float(bnd_box.find("xmin").text),
ValueError: could not convert string to float: '335,91'
During handling of the above exception, another exception occurred:
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 390, in <module>
execute()
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 384, in execute
del data_bunch
UnboundLocalError: local variable 'data_bunch' referenced before assignment
Failed script (null)...
Failed to execute (TrainDeepLearningModel).
Failed at Wednesday, 07 June 2023 20:28:05 (Elapsed Time: 0,45 seconds)
PavanYadav
Hi @DimasPratamaPutra
Notice, "ValueError: could not convert string to float: '335,91'" in the above error.
Looks like when the training data was created your OS or ArcGIS Pro language was set to a language that uses command for decimal.
The Train Deep Learning tool currently only support 'period' for decimal. In the older releases of ArcGIS Pro, the Export Training Data tool used to use language setting for numbers. In newer release, the tool  use dot for decimal. Hope this helps.
A side note: We have an ArcGIS Image Analyst dedicated community and here you might get response sooner on your imagery related questions.
Cheers!
Pavan Yadav | Product Engineer - Imagery and AI
Esri | 380 New York | Redlands, 92373 | USA
https://www.linkedin.com/in/pavan-yadav-1846606/
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
