Failure to package project with a toolbox in pro
5617
7
11-16-2020 12:08 AM
OliverCowan
Good day,
My attempts to package my project keep failing with the error code tatus: "Failed ErrorMessage: ERROR 001659: Consolidating toolbox C:\GIS\Seg_Processing_ARCPRO\Seg_Processing_ARCPRO.tbx"
 The model works fine when I run it; however it includes and Iterator. I'm aware that the Iterator function is strictly a model tool and does not translate to python script.  Could this be the reason for the failure to package my project?
TIA
DanPatterson
MVP Esteemed Contributor
The error...
001659: Consolidating toolbox <value>
has a suggestion.  Did you get the report from
Analyze Tools For Pro (Data Management) ?
... sort of retired...
OliverCowan
Thanks for the feedback. I ran the Analyze Tools For Pro and received the below...
"ERROR 000989: Python syntax error: within script C:\GIS\Seg_Processing_ARCPRO\Seg_Processing_ARCPRO.aprx
Failed to execute (AnalyzeToolsForPro)."
Do you know if it is possible to isolate where exactly the syntax error is occurring?
DanPatterson
Have you opened the script up in a python IDE to check for syntax errors?
If it is a model, then try
exporting-a-model-to-python
If it is relatively short, you can post a copy of the code here
OliverCowan
Essentially, in my project folder I have an input folder with shapefiles of  (A) species distribution records (points) which I need to 'intersect' and spatially join with a large multipolygon shapefile stored within the project GDB (B). The output (the specific polygons from B which contain points from A) are then saved in a n output folder within the project folder. The toolbox I created with modelbuilder does this for me but when I try saving the project as a package the error as listed in my OP pops up. Below is the code from my model that I exported to python window (I see that Iterators are unwelcome in Python, perhaps that is the syntax error that is coming up?):
PS. Thank you vey much for your help, it is hugely appreciated!
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2020-11-16 13:04:46
import arcpy
import os
def FeatureClassGenerator(workspace, wild_card, feature_type, recursive) :
with arcpy.EnvManager(workspace = workspace):
dataset_list = [""]
if recursive:
datasets = arcpy.ListDatasets()
dataset_list.extend(datasets)
for dataset in dataset_list:
featureclasses = arcpy.ListFeatureClasses(wild_card, feature_type, dataset)
for fc in featureclasses:
yield os.path.join(workspace, dataset, fc), fc
def Model(): # Segment Processing
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.env.overwriteOutput = False
Fixed_Segments_5_ = "C:\\GIS\\Seg_Processing_ARCPRO\\Seg_Processing_ARCPRO.gdb\\Fixed_Segments"
Input_Species_For_Processing = "C:\\GIS\\Seg_Processing_ARCPRO\\Input\\Input_Species_For_Processing"
for FeatureClass, Name in FeatureClassGenerator(Input_Species_For_Processing, "*.shp", "POINT", "RECURSIVE"):
# Process: Select Layer By Location (Select Layer By Location) (management)
Fixed_Segments_Layer, Output_Layer_Names, Count = arcpy.management.SelectLayerByLocation(in_layer=[Fixed_Segments_5_], overlap_type="CONTAINS", select_features=FeatureClass, search_distance="", selection_type="NEW_SELECTION", invert_spatial_relationship="NOT_INVERT")
# Process: Spatial Join (Spatial Join) (analysis)
Name = "FeatureClass"
_Name_shp = fr"C:\GIS\Seg_Processing_ARCPRO\Output\{Name}.shp"
arcpy.analysis.SpatialJoin(target_features=Fixed_Segments_Layer, join_features=FeatureClass, out_feature_class=_Name_shp, join_operation="JOIN_ONE_TO_ONE", join_type="KEEP_ALL", field_mapping="fid_1 \"fid_1\" true true false 8 Double 0 0,First,#,Fixed_Segments_Layer,fid_1,-1,-1;cat \"cat\" true true false 4 Long 0 0,First,#,Fixed_Segments_Layer,cat,-1,-1;ogc_fid \"ogc_fid\" true true false 4 Long 0 0,First,#,Fixed_Segments_Layer,ogc_fid,-1,-1;area \"area\" true true false 8 Double 0 0,First,#,Fixed_Segments_Layer,area,-1,-1;region \"region\" true true false 254 Text 0 0,First,#,Fixed_Segments_Layer,region,0,254;Natural_me \"Natural_me\" true true false 8 Double 0 0,First,#,Fixed_Segments_Layer,Natural_me,-1,-1;layer \"layer\" true true false 100 Text 0 0,First,#,Fixed_Segments_Layer,layer,0,100;path \"path\" true true false 200 Text 0 0,First,#,Fixed_Segments_Layer,path,0,200;Shape_Leng \"Shape_Length\" false true true 8 Double 0 0,First,#,Fixed_Segments_Layer,Shape_Length,-1,-1;Shape_Area \"Shape_Area\" false true true 8 Double 0 0,First,#,Fixed_Segments_Layer,Shape_Area,-1,-1", match_option="INTERSECT", search_radius="", distance_field_name="")
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace=r"C:\GIS\Seg_Processing_ARCPRO\Seg_Processing_ARCPRO.gdb", workspace=r"C:\GIS\Seg_Processing_ARCPRO\Seg_Processing_ARCPRO.gdb"):
Model()
DanPatterson
@OliverCowan you forgot to past within code blocks.
Click on the 3 dots, ... , then select the </> , then select Python and insert your code to get it formatted. as in this example from your code
which begs the question... do you want to overwrite outputs? or not.
Are all your data locateable?
On a quick look, I can't see where if recursive is set
Did you run the compatability check I suggested?
OliverCowan
import arcpy
import os
    dataset_list = [""]
    if recursive:
    arcpy.env.overwriteOutput = True
        Model()
my apologies-have amended above.
wrt to overwriting outputs at this stage it doesn't really matter but I have changed it to "=True".
Data should be locatable - the input shapefiles are within folders in the project folder.
The compatibility check reported a syntax error in script...
DanPatterson
Is suspect you need to replace "RECURSIVE" with True
because this code section won't work since it is looking for a boolean
    dataset_list = [""]
    if recursive:
and this block won't run at all since dataset_list is empty
