Failed to Open Project
1395
03-30-2020 04:52 AM
ElielSiqueira
I'm having problems to open my recent projects created in arcgis Pro, when I try to open the project I receive this message:
I'm using the newer version of ArcGIS PRO (2.5), so it shouldn't happen.
If someone has a solution for this problem please give a answer, it'll be very helpfull! I have a lot of projects with the same error.
Robert_LeClair
Esri Esteemed Contributor
Eliel - interesting.  I have not seen this error before.  I'd strongly recommend you contact Esri Support Services to investigate the error.
DanielGoss
Did you manage to fix this problem? If so, what did you do?!
