Failed to Load Data in Attribute Table After Join
2430
5
12-16-2024 01:03 PM
McKenzieBredemeyer
I have a shapefile that I have joined to an Excel spreadsheet and the join was successful, but when I open the attribute table and try to sort a field, an error message pops up the first time saying, "Failed to load data." with "An invalid SQL statement was used." in the More Info section. All the subsequent times I try to sort the table, the main error message changes to "Failed to create the sorted table cursor." but it has the same statement in the More Info section. I am able to sort the attribute table for the shapefile without the join just fine. I am using ArcGIS Pro 3.3, and both my shapefile and Excel sheet is on a SharePoint drive. I have never run into this error before, whether doing joins or not.
Robert_LeClair
Esri Esteemed Contributor
So what I'm seeing in the internals is the issue is with the shapefile (for some reason) and is resolved when you export the shapefile to a file geodatabase feature class.  Once this is done, build the join on the fGDB feature class and the Excel file.  Sorting should work as expected.
Robert_LeClair
McKenzieBredemeyer
Thank you! Doing the join in the file geodatabase worked.
SOONGKITWONG
I did something along this line and it sort of worked but now for some reason that layer is suuuper slow and laggy.
Robert_LeClair
@SOONGKITWONG - is the geodatabase local, on a shared network drive, or on OneDrive?
KeithAddison1
This happens to me sometimes, thankfully I don't have to sort on any join fields so I just remove the join to make it go away.  Source data is in SDE not .shp
