Hello everyone, I'm having an issue right now with my ArcGIS Pro which has forced me to uninstall and reinstall the app as well as install all its deep learning packages for smooth operation. Its the Train Deep Learning Model tool. I've used this tool before and I didn't experience any glitch last week but now its refusing to run. I'll share a screenshot of the error report below. Please I need help as to what could be the problem and possible solution. Thank you
Did you follow this when you reinstalled everything?
Install deep learning frameworks for ArcGIS—ArcGIS Pro | Documentation
Did you try to use a previous dataset that you know worked? Or is this a new data set?
The error message suggests that something isn't installed (PIL? )or installed with an incorrect version.
yes I used a previous Dataset that it worked for.
make sure you have the correct conda environment activated before you use the tools and that you installed Pillow.
(conda install Pillow=6.1.0). The error at the end says it can't find the appropriate dll associated with it
From Install and set up | ArcGIS for Developers for Pro 2.5, the install recommendation was
conda install -c esri -c fastai -c pytorch arcgis=1.8.1 scikit-image=0.15.0 pillow=6.2.2 libtiff=4.0.10 fastai=1.0.60 pytorch=1.4.0 torchvision=0.5.0 --no-pin
check your conda list against the versions assuming you installed arcgis and want to use notebooks
