Failed to execute rename
4678
7
11-20-2020 01:47 AM
IreneChristoforou
Hi everyone. Error 160506. Failed to execute rename. The data owner of the FD cannot rename feature classes. The data owner has advance license.
DanPatterson
MVP Esteemed Contributor
How are you renaming?
/rename-geodatabase
data-management/rename
Any other details would help
... sort of retired...
IreneChristoforou
try to rename gisdb."GOVCY\ZZOMENI".GeologicalSuitabilityZones to gisdb."GOVCY\ZZOMENI".GeologicalSuitabilityZonesJan2020
IreneChristoforou
We use this procedure:
right-click the feature class in the Catalog pane, click Rename, and type a new name
DanPatterson
try renaming the last bit as
GeolSuitabilityZonesJan2020
I remember something about not exceeding 32 characters, but I can't find it
VinceAngelo
Esri Esteemed Contributor
It's actually a 31-character limit (buffer is size 32, including the terminating NUL character).
Aliases can go to 64 characters, but the name must still be < 32.
Note that the above was from before 10.8, so it depends on the release level of the
enterprise geodatabase.
- V
George_Thompson
Esri Notable Contributor
Here is the information on naming limits: https://pro.arcgis.com/en/pro-app/help/data/geodatabases/manage-sql-server/enterprise-geodatabase-li...
The length does not look like an issue.
Is there another ArcGIS client (Desktop / Server / Enterprise / etc.) connected to that table?
Are there any other locks on the table?
--- George T.
BillFox
MVP Notable Contributor
try compressing the geodatabase to state zero first
