Failed Script Error calculating area of polygon
1670
11-20-2024 02:43 PM
GeoffFreer
Im getting the following error calculation Area (Geodesic). I have successfully done this on this layer previously but not with a new polygon I just added
Calculate Geometry Attributes
Parameters
Input Features SRK_Resource_Area
Geometry Attributes Area AREA_GEODESIC
Length Unit
Area Unit SQUARE_KILOMETERS
Coordinate System PROJCS["GDA_1994_MGA_Zone_54",GEOGCS["GCS_GDA_1994",DATUM["D_GDA_1994",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",10000000.0],PARAMETER["Central_Meridian",141.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Updated Features SRK_Resource_Area
Coordinate Format SAME_AS_INPUT
Messages
Start Time: Thursday, 21 November 2024 9:36:07 AM
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\calculategeometry.py", line 366, in <module>
CalculateGeometry(fc, properties, lUnit, aUnit, cs, cformat)
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\calculategeometry.py", line 155, in CalculateGeometry
srow = next(scur)
StopIteration
Failed script Calculate Geometry Attributes...
Failed to execute (CalculateGeometryAttributes).
Failed at Thursday, 21 November 2024 9:36:10 AM (Elapsed Time: 2.80 seconds)
DanPatterson
MVP Esteemed Contributor
Repair Geometry (Data Management)—ArcGIS Pro | Documentation
I would use it to check and fix the geometry before calculating geometry
... sort of retired...
GeoffFreer
Thanks Dan
Ran the tool but still getting the same error
DanPatterson
Calculate Geometry Attributes (Data Management)—ArcGIS Pro | Documentation
now if you used the tool above and got that error,  and repair geometry didn't catch any errors in the geometry, is it possible to copy that particular polygon to a separate featureclass and delete it from the one you are working in to see if it is the actual geometry or something in the featureclass.
GeoffFreer
Hi Dan
I recreated in a new shp and it worked. Thanks for your help!
DanPatterson
glad it worked out
