Failed Conversion of S-57 to S-101 Cell (Maritime Tools) in ArcPro 3.6 version
327
03-18-2026 07:16 PM
EmmanuelRegondola
Could you assist us in resolving an issue we’re encountering when converting an S-57 cell to an S-101 cell in Maritime Tools using ArcGIS Pro 3.6? The process fails with the following error message: ERROR 999999: An unexpected problem caused the tool to fail. Please contact Esri Technical Support (http://esriurl.com/support) to report this bug, and consult the error help for possible solutions or workarounds. We would appreciate your feedback. Thank you.
DanPatterson
Beyond possible causes listed in the following link, it is usually best to follow the advice and contact Tech Support
999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl...
... sort of retired...
Tobias-Venable
Hi Emmanuel,
That's a less than helpful error message which we try to avoid! Would this S-57 cell be a file you could share to help troubleshoot your particular issue? If so, you could send it to maritime@esri.com.
We have more enhancements coming in the Pro 3.7 release for the Convert S-57 to S-101 Cell geoprocessing tool, but I would like to insure your issue is resolved.
Thank you!
