Extract value from a one line shape file arcpy
3570
03-17-2021 01:27 AM
MohamadAchour
Hello,
I have a shapefile that contains one line, and I need to extract the "Shape Length" value from his attribute table using python.
Any suggestion?
Tags (3)
DavidPike
MVP Notable Contributor
a search cursor will do the trick SearchCursor—ArcGIS Pro | Documentation
import arcpy
fc = 'c:/data/your_shapefile.shp'
#look at the geometry tokens in the help url
#for more understanding
fields = ['SHAPE@LENGTH']
#open cursor
with arcpy.da.SearchCursor(fc, fields) as cursor:
    #for every row in the shapefiles attribute table
    for row in cursor:
        #row[0] is the first field specified when opening the cursor
        #next field rould be row[1]...etc
        #print the length
        print(row[0])
JayantaPoddar
Where do you want to extract it to?
Using Python Parser of Field Calculator?
!shape.length@<units>!
e.g.: For calculating length in yards
!shape.length@yards!
Geometry Calculation
Think Location
MohamadAchour
I only need the value of the "shape length" cell. Then, I will use this value in the script.
MohamadAchour
if there is a method to calculate the length of the polyline also it can work.
DavidPike
import arcpy
#open cursor
    for row in cursor:
        #print the length
        print(row[0])
