Extract Multi Values to Points - EGM2008
708
11-09-2025 09:34 PM
Y_Chau
I get ellipsoidal heights in feature geometries from Field Maps. We have this tool in ArcGIS Pro - Extract Multi Values to Points. Where can I get a EGM2008 surface to extract geoid separation for each point using this tool? Then I will be able to calculate geoid heights.
YC
Tags (3)
tikola
by Esri Contributor
I am not sure can you really get a surface to calculate difference, but this will help in topic generally:
https://pro.arcgis.com/en/pro-app/latest/help/mapping/properties/arcgis-coordinate-systems-data.htm
By adding this additonal installer you can easily convert ellipsoidal heights to EGM2008 in ArcGIS Pro
