Exporting map to pdf with CMYK values option in Pro
4300
5
03-14-2018 02:38 PM
WesleyKoros
I've a map designed in ArcMap with all CMYK values correct, during export of the map to pdf ; 'Destination Colorspace'  can easily be switched between RGB and CMYK. I want to open the same map document in ArcGIS Pro and export to pdf with same CMYK values maintained. I can't see 'destination colorspace' to choose CMYK option? Does Pro assume RGB only during export?
DanPatterson_Retired
Was it authored with CMYK? since it is supported on creation http://pro.arcgis.com/en/pro-app/help/mapping/map-authoring/maps.htm
and support was added for export since PRO 1.4 http://pro.arcgis.com/en/pro-app/get-started/whats-new-in-arcgis-pro-1-4.htm
WesleyKoros
Thanks Dan, map document was authored in ArcMap with CMYK values .
Then the http://pro.arcgis.com/en/pro-app/help/mapping/map-authoring/maps.htm link says
"The color model is set on the General tab of the Map Properties dialog box.
but you do if from the Map, Properties settings and not the Layout properties"
WesleyKoros
Thanks Dan, I appreciate heaps! That means version 2.1 of Pro is all good with CMYK.
So you can close the question then if all is good.
