Exporting layouts with label issues
3299
09-18-2017 11:09 AM
JulieDel_Muto
We are having issues with exporting in regards to labels and text. When exporting to a PDF, PNG or a JPEG we have noticed that sometimes labels disappear or are moved or duplicate. Is there a way around this or something we are missing in ArcPro when exporting a layout that is different from ArcMap? Thanks!
MichaelVolz
Esteemed Contributor
Can you provide some details on the datasources for the data where the labeling problems occur?
JulieDel_Muto
Hi! Yes, it happens with shapefiles/geodatabase layers. Below are screenshots of the ArcPro layout and below that an export of it as a PNG.
 ArcPro
PNG
MichaelVolz
So it does not appear that different datasources have an impact on the labeling issues.
What version of Pro are you using where you see these labeling issues?
My org is in the preliminary stages of migrating from Desktop to Pro, so I am interested in seeing if I can duplicate the labeling issues you are seeing in my environment.  I will let you know if I can replicate your issues in my environment.
JulieDel_Muto
The latest version, I just need to install the new patch that came out.
Thanks! Let me know if you see an issue!
GuyCochrane
My feature labels are not showing up in the jpeg layout export. I switched to Standard from Maplex and removed limits on the visibility range. What else can I do?
