exporting feature class with labels to kmz
928
02-18-2026 11:37 PM
carson_schuetze
I have a feature layer containing lines and i have gotten the labels to look "pretty". I now need to export these lines and labels to a KMZ - customer wants to see exactly what i'm seeing - the lines and labels exactly as they are in Pro. obviously just sharing the feature class doesn't preserve the labeling i've displayed on the map. here's what i've tried:
1- labels -> graphics. graphics -> features (annotations). merge the label features + the line features - fails because you can't merge annotations to lines.
2- labels -> graphics. graphics -> features (polylines). failed to make the letters into polylines. fair enough.
3- feature outline mask for the label feature class - failed due to a bug that 3 others have reported on ESRI since 2020 - this tool does not work for annotations specifically.
4- saving as a tif, colorizing so that only the lines and letters are visible, and the background is transparent. this symbology didn't carry over when i shared the tif. (this was just a desperate attempt to get something to work)
is there something i'm missing? this seems like it should be a relatively easy task but i've been banging my head against the wall on it for an hour and a half. i cannot post my data or screenshots due to privacy concerns, so i hope i've described the problem well enough.
Tags (3)
DanPatterson
MVP Esteemed Contributor
So using  Layer To KML (Conversion)—ArcGIS Pro | Documentation
doesn't work?
Perhaps you need to share the layer or the map if they have Pro installed.
Share a layer package—ArcGIS Pro | Documentation
Share a map package—ArcGIS Pro | Documentation or its webmap equivalent
... sort of retired...
XiaoXiao2
Can you just try Layer to KML, it should export the labels as well. If not, can you share the data with me?
Melissa_B
You'll have to convert the lines to points, label the points, and export both to kml:
https://support.esri.com/en-us/knowledge-base/labels-do-not-appear-in-google-earth-after-converting-...
The Map to KML and Layer to KML tools don't add labels to polygon and line features, unfortunately.
