Exported Movie Extent Not Matching Locked View Size Extent in Pro Animation
1154
03-17-2023 10:24 AM
KathrynCross1
I'm attempting to create a movie with historical maps and aerial images fading into each other through time in ArcGIS Pro 3.1.0. I cannot get the extent of the map in the exported video to match the extent of the keyframe I'm seeing when creating the animation keyframes with the Lock View Size function on, no matter what resolution I export to. The frame appears far more zoomed out than what I'm working while creating the animation. Am I doing something wrong?
brock82
I'm basically having the same issue. Does anyone out there have suggestions?
kennedy
Did anyone ever figure this out? I'm having the same issue. What's even more frustrating is that it was working for several weeks while working on an animation and now, out of the blue it's not working on a desktop computer running 3.1 and my laptop running 3.2. I've tried everything and have an open case with tech support. They are not having the issue when using my Pro project. It works fine for them and they cannot replicate the issue. On my system, when I "Lock View Size", it crops in the horizontal extent (on the screen) but not in the vertical extent. On the export, the map is zoomed out more than on the screen in the animation on the horizontal and vertical extent.
DKubenka_SCG
Having the same issue...
mapkamp
Same issue!! It all matched at first, but now the extent is different (even with the view size locked) and the size of all elements like text and symbols looks totally different once exported. I set the resolution while working but I wish there was a more reliable preview mode. I had all of my keyframes set just right for panning around and now things are cut off or too zoomed out once the ani is exported. Looks totally different. Very frustrating!
