Hi, is there a way to export the water flow rate (m^3/s) from a flood simulation? Currently, it seems that only “water depth,” “water absolute height,” “water velocity vector” as U-V, and “water speed” can be exported. Strangely, there is no option to export the water flow rate.
Or am I missing something?
(I know that I can calculate the flow rate myself based on the water depth and water velocity. But it would be much easier if you could export it directly)
