thanks for the suggestion, jayanta. i tried it, but the results didn't improve much. here are some screenshots to illustrate the problem. i wonder if i am just not using the tools right. i added a D size layout (very big paper). i added the map (light gray canvas) to the layout. i exported using ping and 1000 DPI. that should give something like 24,000 pixels in height since D size is 24". i used 8 bit gray scale output. the file is very big (16MB), but the png image is not good. here are screenshots of the png export (first image here) and the screen i see in arcgispro map view (2nd image). .
the export seems to blur the image a lot, even though i choose high DPI. the png file is 16MB, so the problem is not a lack of pixels. i tried various other output formats - bmp, jpg - but had similar results (both are a bit worse than png). it seems like i must not have the export set up right, but there are only a few things to pick.
i tried with very high (3000) DPI and E size layout and still got poor results. the output png file was 190MB but still the image is pretty blurry.
i'd appreciate any suggestions you have
thanks!
j
