EXPORT TO CAD or dwg file
4896
11-06-2020 02:14 PM
KathrynThoden
RE: Export to CAD or EXPORTCAD command in ARCGIS Pro
Where is it? I found a great online explanation of the command, would like to use it and can't find it in the menu, toolboxes, and have no idea where to enter the command and its syntax in ArcGIS Pro.  Please show me how to get into this command? I would simply like to take section lines from a feature layer and import them into a dwg file.
Thank you for replying~
LukasFalk
Hello Kathryn,
I'm running ArcGIS Pro 2.6.2 and I was able to find the Export to CAD tool by searching it in the Geoprocessing pane (attached image).  This tool is available with all licensing levels so you should have access to it.  To access the Geoprocessing pane in order to search this tool, hit the Analysis tab and then the Tools button.
I hope this helps!
Lukas
