Export to CAD (.dgn) reserved field changes?
886
05-07-2024 10:02 AM
JC-220
Hello all,
I recently updated my from ArcPro 3.1.1 to 3.2.2 (arcpy-base 3.2 py39_49690) and now am having an issue with the Export to CAD tool while using arcpy. My script creates points and labels them in a .dgn using the Reserved CAD fields. Using the prior 3.1 as as well as arcpy 2.9 I was able to control text with with the reserved "TxtWidth" field. Now in arcpy 3.2 my text has no width and is effectively invisible.  I've tried using other width or size related fields including "TxtBoxWd" and nothing is working. Is anyone else having this issue? Again, the same script works as expected in arcpy 2.9 and only the "TxtWidth" field seems affected so far.
