Export raster to PDF
1711
07-07-2023 01:10 AM
akshay7646
I have a need to geo-reference a paper map and export it out as a GeoPDF for use in Avenza. This is a workflow I used to do quite a bit but haven’t done recently. I can’t seem to export to PDF anymore. Has that been removed https://vlc.onl/ ? Am I missing something?
LeslieUK
Hi @akshay7646
The functionality of exporting to PDF should still be in ArcGIS Pro. You can find it in the Share Ribbon > Export Map:
I hope that helps!
~Just trying to fix things~
LeslieUK
Hi @akshay7646
I hope that helps!
DanPatterson
MVP Esteemed Contributor
with details in the help
Export to PDF—ArcGIS Pro | Documentation
... sort of retired...
