Export map will not export as vectors (EPS, SVG, or PDF)
2900
11-08-2023 03:53 PM
Janus
I can't believe I'm having trouble with something so simple, but my maps will not export as vectors, no matter the settings I try.
I am using simple shapefiles and have tried "export map" as EPS, SVG, and PDF file types with "output as image" unchecked. When I open the files in Illustrator, there is only one layer: an image layer.
I have only one layer turned on in ArcGIS, and there is no transparency.
This is the same simple problem occurring in other posts like this, which has not been answered. https://community.esri.com/t5/3d-mapping-questions/scene-exporting-to-image-instead-of-vectors-in-sv...
Any suggestions?
Janus
Still no resolution. It must be a bug. The software is useless for me if I can't export vectors. I can't even download older versions of ArcGIS, only 3.2.0, because of how Esri controls organizational downloads.
CraigBrigley
I'm also trying to achieve this.  For high quality publications, I need to share / export a map in vector format.  This worked well in ArcMap.  I usually used the EMF format that works well with Microsoft Office.
FrancesHamilton
I am having the exact same problem.
