Export Layout Pdf Metadata for Map Series
440
04-22-2026 09:17 AM
AndrewDeLuca
I have a map series of picnic locations for my jurisdiction and need to add a Title to the PDF metadata during export of each map, but I would like to use the map title as a variable in the title export. The issue is the input is just standard text, so even if I want to export all 44 maps they would all have the same PDF Metadata Title. Is there a way to use a map or page element in the export pane so each exported PDF has a different Metadata Title? Is there a plan to add that functionality to Map Series if not? It is quite a task to manually add that to each exported PDF.
BrennanSmith1
BrennanSmith1
