Export feature class to shp file
1386
01-21-2022 09:26 AM
by Anonymous User
Not applicable
I have a 1.7 million record feature class that I need to export to a shp file.  When I run feature class to feature class/feature class to shp file the shp file has less than half of the points (470,000) loaded.  What is the workaround?
Robert_LeClair
Esri Esteemed Contributor
Hmmm...shapefiles are limited to 2 GB in size so I wonder if you're hitting the storage limit perhaps?  And this information about limitations as well.
by Anonymous User
Not applicable
https://pro.arcgis.com/en/pro-app/latest/tool-reference/appendices/geoprocessing-considerations-for-...
It's the very first hit and an almost identical question in the "Related" bar...
Looks like shapefile limitation.
DanPatterson
an ugly alternative, depending where it needs to be used
Features To JSON (Conversion)—ArcGIS Pro | Documentation
... sort of retired...
