Export Error in ArcGIS pro
2285
06-28-2020 04:08 AM
AdebisiNaheem
Hi Pro users,
I am having issues exporting my layout in ArcGIS pro. The error is 'Export cancelled'. I have different file type, PNG, JPEG, SVG and various resollution. I have also changed the location of my export to different folders but the export won't still work. Please see attached.
kindly suggest what to do. I am running ArcGIS pro version 2.5.2 on 8GB RAM core i5 CPU system.
Thanks.
MichaelVolz
Esteemed Contributor
Do you know if you have write permissions to the folder you are trying to save to?
Maybe try saving to a different location such as where the aprx file is saved and see if you have more success.
Also, I'm at a lower version 2.4.2 and the Export Layiout dialog box looks different where it does not have a slide bar for setting compression quality.
Maybe also try lowering your resolution dpi just to find a resolution that will not throw an error.
