Export Bivariate Spatial Association Results
78
Wednesday
LuisaSchneider
I used the Bivariate Spatial Associations (Lee's L) tool and want to export the results as a shapefile. ArcGis always gives me this error:
ERROR 002809: Field OBJECTID in BSA_F is of an unsupported type for the output workspace.
Does anyone know how to export the attribute table as a shapefile or geopackage to keep the spatial information?
Thank you!
DanPatterson
try exporting to a featureclass/table in a file geodatabase. shapefiles don't support 64 bit objectids
002809: Field <value> in <value> is of an unsupported type for the output workspace.—ArcGIS Pro | Do...
you could downgrade it after (see the link) and try to get it to a shapefile if you must
Addendum
If the objectid isn't 64 bit did you navigate to a folder to specify the output shapefile, ensuring you added *.shp to the filename?
... sort of retired...
