Excel Tool in ArcGIS Pro
1346
12-22-2022 03:17 AM
denniszammarchi
Hello, is there an alternative to manually installing the Microsoft Access Database Engine Drivers (https://pro.arcgis.com/en/pro-app/latest/help/data/excel/prepare-to-work-with-excel-in-arcgis-pro.ht...to use the tools "Excel to Table" and "Table to Excel" in versions 3.0 (or later) in ArcGIS Pro?
DanPatterson
MVP Esteemed Contributor
Your link covers the methods.  What is the problem you are having with the procedure?
... sort of retired...
AyanPalit
Guide to connecting to Excel files in ArcGIS Pro
Ayan Palit | Principal Consultant Esri
RhettZufelt
MVP Notable Contributor
Not if you want to connect directly to, or export to Excel format.
But, you can always save as csv/txt from Excel and then load the csv.  Excel can also open csv's/txt's exported from Pro.
R_
