ESRI Arcgis Pro not detecting video memory in Windows 11 VM
659
07-22-2024 07:18 AM
Giovanni_Tedeschi
Hello
I am working with Arcgis Pro 3.3 on a Windows 11 VM on a MacBook Pro M3 Pro with 36 GB UMA. Considering some issues with the application, I have run the requirements detection tool and found out that Arcgis Pro doesn't see the video memory wich is necessary to run some application. See attached image 1.
In parallels I have configured the memory assignment to auto following this kb article
https://kb.parallels.com/125351?alid=570003536.1721221950#section1
The parallels configuration shows that I should have "up to 9 GB for graphics", but I cannot retrieve this information in Windows.
How can I make the app Arcgis pro read correctly the video memory?
Second problem, how can I install the OpenGL Extension ARB_Clip_Control?
Thanks.
Giovanni
DanPatterson
MVP Esteemed Contributor
ArcGIS Pro 3.3 system requirements—ArcGIS Pro | Documentation
See the hardware requirements under
General-purpose computing on a GPU
... sort of retired...
