Error while using Train deep learning model tool
1704
02-20-2021 01:40 PM
Noha
Hello Everyone,
Could anyone help me please in deep learning tools?
I am trying to run train deep learning model tool, unfortunately, I got the error in the screenshot
I am using ArcGIS pRO 2.7 and I installed the Deep Learning Framwork based on  https://github.com/Esri/deep-learning-frameworks/blob/master/README.md?rmedium=links_esri_com_b_d&rs...
ahmed_hussiney
This error may indicate training data issue, Have a look on the following post it could help you fix the issue
https://community.esri.com/t5/arcgis-api-for-python-questions/arcgis-learn-prepare-data-error-callin...
I recommend also you follow the following ArcGIS learn lesson, as it give a step by step guide to train a deep learning model in ArcGIS pro with a sample data.
https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health/
Robert_LeClair
Esri Notable Contributor
Are you licensed for Image Analyst by chance?  The error is talking about an Image Analyst toolbox it seems so I'd check my licensing first.
Noha
Thank you very much,
Yes, image analyst is licensed
So, I uninstalled ArcGIS pro 2.7
Then, installed ArcGIS pro 2.6 and the deeplearning framework
According to the tutorial https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health
Unfortunately I get the error in the photo while selecting the input data that obtained from export training data for deep learning model
