Error when consolidating Python Web Tool. Not all the reference code is consolidated
1086
07-29-2024 05:39 AM
Cristian_Galindo
In version ArcGIS Pro 2.9,3.0 and 3.1 the following structure of a web tool work as intended:
Updm2018
└── TestService.atbx
├  __init__.py
├  MyTestService.py
├  foo.py
└──bar
    ├ __init__.py
    ├ real_bar.py
    ├ file_required_by_baz.json
    └─ baz.py
The definition was staged  using the StageService function and the .sd file will include the required files.
Note: I also tried using the Save As Offline Service Definition tool:
It is worth to mention that the file MyTestService.py include the imports:
import foo
from bar import realbar
from bar import baz
Execution of the tool StageService in ArcGIS Pro 3.3.1 generates an .sd file with the following structure (.sd file is just a zip file):
│   manifest.xml
│   serviceconfiguration.json
│   tilingservice.xml
├───cd
│   └───updm2018
│           foo.py
│           MyTestService.py
│           TestService.atbx
├───esriinfo
│   │   iteminfo.xml
│   └───metadata
│           metadata.xml
└───p30
        MyTestService.msd
        MyTestService.rltx
        MyTestService.tbx
There are missing files required by the tool to properly run:
real_bar.py
baz.py
The attached file contains the structure folder and Web Tool to reproduce the issue.
Following the indications of the documentation , it should be possible to do it. As a matter of fact it has been working with out any issue, until this version.
Cristian_Galindo
Hello people from the future, in my mirrored post in gis.stackexchange one of the users said:
"I chatted with the Esri Geoprocessing Services Team -- they confirmed this is a bug and have entered a ticket into their system. I can't make any promises on their behalf, but they've set a target to fix in ArcGIS Pro 3.4"
if that is true, I can't afford such delay, therefore I had to figure a solution:
1. In root level, I created a file called modules_importer.py:
Updm2018
├  __init__.py
├  MyTestService.py
├  modules_importer.py
├  foo.py
└──bar
    ├ __init__.py
    ├ real_bar.py
    └─ baz.py
 2. Inside the file I put the following code:
import arcpy
import sys
from os.path import exists
def set_path():
    bar_module = r".\bar"
    if exists(arcpy.env.packageWorkspace + '\\..\\cd\\'):
        sys.path.append(arcpy.env.packageWorkspace + '\\..\\cd\\')
3. Modified the imports of the file MyTestService.py:
import arcpy
import foo
arcpy.AddMessage("Loading own modules")
import modules_importer
modules_importer.set_path()
arcpy.AddMessage("AfterLoading own modules")
import bar.real_bar as real_bar
import bar.baz as baz
4. When the stage definition is created, is very important  to select the Copy all data option (in ArcGIS Pro):
or its equivalent  in python: setting True the property copyDataToServer in the GeoprocessingSharingDraft class.
when all this is set, the creation of the .sd file will consolidate, and the file structure will be:
│   manifest.xml
│   tilingservice.xml
├───cd
│   ├───updm2018
│   │        foo.py
│   │       MyTestService.py
│   │       TestService.atbx
│   └───bar
│           real_bar.py
│           file_required_by_baz.json
│            baz.py
├───esriinfo
│   │   iteminfo.xml
│   └───metadata
│           metadata.xml
└───p30
        MyTestService.msd
        MyTestService.rltx
        MyTestService.tbx
and the file modules_importer.py will be consolidated as:
# Esri start of added imports
import sys, os, arcpy
# Esri end of added imports
# Esri start of added variables
g_ESRI_variable_1 = os.path.join(arcpy.env.packageWorkspace,'..\\cd\\bar')
# Esri end of added variables
import arcpy
import sys
def set_path():
    bar_module = g_ESRI_variable_1
    # pythonModules = r".\\" # this line make a recursive call to the current folder
    arcpy.AddMessage("Call set_path")
    arcpy.AddMessage(arcpy.env.packageWorkspace + '\\..\\cd\\')
