Error When Adding Features to Map From Database Connection
862
10-29-2025 01:54 PM
MaxwellMiller_
ArcGIS Pro 3.5.4
I have a PostgreSQL database with the PostGIS extension that I have connected to successfully and want to add features to the current map. I right click and select 'Add to Current Map' and I get the following error message.
'Attribute column not found[ERROR; column "county" does not exist Line 1: select * from (select COUNTY, BOOK, MAP, PARCEL, SPLIT, ...'
I read somewhere on the ESRI forums that both the database column names need to be in lowercase. I would recommend that the error message be improved to detail that fact.
MaxwellMiller_
I am commenting to show a solution for those who have the privileges to add functions and are comfortable with PostgreSQL.
 Within psql (PostgreSQL terminal) or pg Admin 4, create the following function:
CREATE OR REPLACE FUNCTION rename_columns_to_lowercase(
    p_schema_name TEXT,
    p_table_name TEXT
RETURNS VOID AS $$
DECLARE
    column_rec RECORD;
BEGIN
    FOR column_rec IN
        SELECT
            c.column_name
        FROM
            information_schema.columns c
        WHERE
            c.table_schema = p_schema_name
            AND c.table_name = p_table_name
            AND c.column_name <> lower(c.column_name)
    LOOP
        EXECUTE format('ALTER TABLE %I.%I RENAME COLUMN %I TO %I',
            p_schema_name,
            p_table_name,
            column_rec.column_name,
            lower(column_rec.column_name));
    END LOOP;
END;
$$ LANGUAGE plpgsql;
Now, you can call on that function to make all of the columns lowercase within a given table:
# Input in the form
# SELECT rename_columns_to_lowercase('schema', 'table');
SELECT rename_columns_to_lowercase('public', 'cv_parcels_county_extent')
After refreshing the connection within ArcGIS Pro, you should be able to add your data to the map. You might be prompted to select a primary key from one of your columns before you can add the table.
MaxwellMiller_
    p_schema_name TEXT,
    p_table_name TEXT
RETURNS VOID AS $$
DECLARE
    column_rec RECORD;
BEGIN
    FOR column_rec IN
        SELECT
            c.column_name
        FROM
        WHERE
    LOOP
            p_schema_name,
            p_table_name,
    END LOOP;
END;
# Input in the form
