Error Message when Deleting Features in Pro
19062
11
02-06-2019 08:28 AM
MaggieWitmer
I recently imported an mxd containing enterprise geodatabase feature classes to an ArcGIS Pro project. The import seems to have been successful, but when I try to delete features from select feature classes I receive the following error message:
"Delete Selected Features Failed. The selection contains no editable features."
I opened a new Project and established a database connection to my sde, but received the same message when I brought in one of my feature classes and tried to delete a feature from it.
I cannot figure out why I am unable to edit features in my sde through Pro.
makabir02
I have solved the same problem in a different way.
I have created a geodatabase, feature dataset and imported the shapefile as feature class. After that it becomes a good boy - no issue with editing.
One issue could be missing of projection information that is .PRJ file. Atleast I have had.
RodrigoIvanCayojaMiranda
This usually happens because the features do not have a defined coordinate system.
