error in deep learning
3076
12-21-2020 06:58 AM
AhmetKarabıyık
hello
i follow application of deep learning in arcgis pro as the gıuidelines expressed in https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health/
i trained the model now for detection of objects by deep learning the error as below stoped the process:
ERROR 160676: The domain name is invalid.
Failed to execute (DetectObjectsUsingDeepLearning).
below is the screenshot of parameters i used
how should i deel with that and what is the problem
i will be so grateful if anyone have a useful recommendation
AndrewEastop
Hi
Did you have any luck getting this fixed? I just had the same problem today.
thanks
FédérationQuébecoisedeKite
I just had the same problem too. Can anyone help?
Judith
FdrationQubecoisedeKite_0-1624972152399.pngFdrationQubecoisedeKite_0-1624972152399.png
AndrewEastop
Hi Judith what version of pro are you using?
I am currently on 2.7 which seems to be the problem. ESRI analyst tried my data with 2.8 installed and it worked ok.
Hi Andrew,
Bullseye! I reinstalled the deep learning plugin and it fixed the issue.
Judith
