Error creating Geodatabase Version ArcGis pro c#
538
07-24-2025 10:40 AM
JuanManuelPazDiaz
Good morning, I am generating a connection to a service where I have my layers hosted,
everything is correct, but when I try to generate a new version,
it shows me the following error: "User does not have privileges to perform this operation." I have already changed the user to one with privileges.
To confirm that the user is correct,
I tried directly from the ArcGis Pro interface and it does allow me to generate versions without any errors.
I don't know if I need to take any other steps.
This is my code
private void Create_Version()
try
Uri nonFederatedServerURL = new Uri("https://procesos/FeatureServer");
ServiceConnectionProperties nonFederatedArcGISServer = new ServiceConnectionProperties(nonFederatedServerURL)
User = "prueba",
Password = "prueba2"
using (Geodatabase geodatabase = new Geodatabase(nonFederatedArcGISServer))
if (geodatabase.IsVersioningSupported())
// Create a VersionDescription object
VersionDescription versionDescription = new VersionDescription("VERSIONPRUEBA", "DESDECODIGO", VersionAccessType.Public);
// Get the current version as the parent (or specify a different parent if needed)
ArcGIS.Core.Data.Version parentVersion = geodatabase.GetVersionManager().GetCurrentVersion();
ArcGIS.Core.Data.Version newVersion = geodatabase.GetVersionManager().CreateVersion(versionDescription, parentVersion);
catch (Exception ex)
MessageBox.Show("error" + ex.Message + " " , "", MessageBoxButton.OK, MessageBoxImage.Information);
Thank you, I hope you can support me.
