Error code 400 when I publish a feature with a Definition query
9340
12-14-2020 01:32 PM
wilcow
I have a feature class in Enterprise GIS that has a related table (simple relationship, 1:M).
I have a definition query on the features based on a field in the related table:
FacilityID_INT IN (SELECT FID_INT FROM SS_Spills WHERE Spill_Overflow IS NOT NULL)
and when I attempt to publish to AGO, it fails with this error in the log: "StatusMessage: Server Response: ERROR: code:400, Invalid URL, Invalid URL, Bad syntax in request."
When I remove the DQ, the feature publishes fine.
I would simply filter the feature layer on AGO after I publish but there's no way that I can see to use subsets or SQL in AGO
Any thoughts on what could be fouled up in that definition query?
Robert_LeClair
Esri Esteemed Contributor
This is a known issue.  One workaround is to export the feature class out to a new feature class based upon the DQ and publish the new layer to ArcGIS Online.  Then you don't have to worry about an ArcGIS Online filter for subsets.
Robert_LeClair
wilcow
Well, thanks for the response.
I was able to publish the FL to Portal with the definition query, but ran into other (separate) issues with that.
Eventually I settled on only publishing the related table to AGO (as a web feature) so I could create a Survey123 form against that.
May still have to resort to a separate feature class as you describe ...
Thanks again!
