Error 210 in ArcGIS Pro / ArcGIS Notebook
3504
6
03-10-2020 02:10 PM
deleted-user-3K8mKpoPb261
Could someone help why I'm having Error 210 on this script?
For info, I'm running the script using ArcGIS Notebook with ArcGIS Pro.
DanPatterson_Retired
a *.dbf file has to go into a folder, If you want a geodatabase table, then a *.gdb needs to be specified
Your workspace name doesn't look right
Actually, my workspace is a folder. I named it specifically like that. And i tried to rename it as well but it's still not working.
Try a folder that is different, or "raw encode the folder path.  Either the \U will make the path unusable, or the \n later on
p = "C:\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf.dbf"
  File "<ipython-input-1-e0812d7d099a>", line 1
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \UXXXXXXXX escape
# ---- raw encoded... a little 'r' goes a long way
p = r"C:\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf.dbf"
print(p)
Thanks, Dan! But is there a way to raw encode the output with TableToTable function. It's asking for both the output path and output name. And there's no option to raw encode the output.
Try ...
ValidateTableName—ArcPy Functions | Documentation
It seems you have your workspace raw encoded, but it either doesn't like it in combination with the new table name.
Also, I don't see
arcpy.env.overwriteOutput anywhere in your script
Checking for the existence of data—ArcPy Get Started | Documentation
Also, I totally recommend not using c:\users for anything unless you are stuck in a shared environment.  If you can make your own folder ensuring the path subfolders don't begin with \g, \t, \u, \a, \b
p = "c:\t\a\n\b"
p
'c:\t\x07\n\x08'
print(p)
c:
# ---- r works, or \\ or /
p = r"c:\t\a\n\b"
print(p)
c:\t\a\n\b
or the os module's path join
p = ['C:\\', 't', 'a', 'n', 'b']
os.path.join(*p)
'C:\\t\\a\\n\\b'
I tried these workaround but it seemed to not have fixed the issue. This script doesn't even work i stand alone as well.
