Error 1935 while installing ArcGIS Desktop in Windows 11
15645
12
01-01-2023 09:12 PM
ankur_soni
An error 1935 is occurred while installing ArcGIS Desktop in Windows 11. I had already installed License Manager and Database Server, but the problem still persists.
While installing ArcGIS Desktop 10.8.2, a message pop up "Error 1935 An error occurred during the installation of assemble component {9BAE13A2-E7AF-D6C3-A01F-C8B3B9A1E18E}, HRRESULT:0x80070005."
Taren_Esri
Hi @ankur_soni
Which .NET Framework version do you have installed?
jogram
I have encountered error 1935 attempting to install ArcGIS. I believe I have .NET Framework 4.8 installed.
jogram
I have this same issue. I believe I have .NET Framework 4.8 installed.
KTuc
I also have the same problem when installing ArcGIS Desktop 10.8.2 on Windows Server 2022 (also with .Net Framework 4.8).
Is there already a solution or workaround for that problem ?
jogram
I was able to install by running the .msi instead of the setup.exe
ParshuramPathave
Not installing in my computer.
Config -
Windows 11
.Net Framework 8.0
Microsoft Visual C++ 2015-2022 installed still the same issue occured
TimHansen
did anyone find a solution to this?
PavelBlazek1
please, I have same problem
TimHansen
For me after much troubleshooting with support and their final suggestion being downgrade to windows 10 or reinstall windows 11. I decided to look into the issue further and found that even though the installer said it was reverting changes all of the arc gis files and registry entries were still there so i used revo uninstaller in hunt mode to find and remove everything arcgis related. Tried the install again and it installed just fine.
