Error 000584 when publishing Layer to KML as a web tool with user-defined input mode
887
05-07-2025 12:39 PM
AliAFGHANTOLOEE
I am trying to publish the Layer to KML tool as a web tool. It works fine when I set the input mode as a choice list. However, when I change the input mode to 'user-defined value' and publish the web tool, I encounter an error after adding a layer and run the tool: ERROR 000584: Implementation of this tool's Validate is invalid. Does anyone know how to resolve this issue?
XiaoXiao2
Can you illustrate the workflow for reproducing? Where and how do you run the tool to encounter the error? Thanks
